DAYTIME RUNNING LIGHT SYSTEM- curious Questions
Dedicated to the G37 Convertible. This forum is for convertible-only content that is NOT covered in the other G-Series forums.
cmesurf
Car: Infinitis, 03 FX35, 07 g35 sedan, 05 FX45, 09 G-vert & 14 Q50S Hybrid AWD
Q1) Why DAYTIME RUNNING LIGHT SYSTEM is not standard in US cars? I think cost/regulations may be the reason!
Q2) Is it possible to have " DAYTIME RUNNING LIGHT SYSTEM" functional in convertible- if yes, what are possible options and possible solutions?
Thanks
Infinitiguy19
Car: 1993 Infiniti Q45 188580 Miles
1994 Infiniti Q45a 240000 Miles
cmesurf wrote:Q1) Why DAYTIME RUNNING LIGHT SYSTEM is not standard in US cars? I think cost/regulations may be the reason!
People can barely stop at stop signs anymore....America is not as strict as Canada.
cmesurf wrote:Q2) Is it possible to have " DAYTIME RUNNING LIGHT SYSTEM" functional in convertible- if yes, what are possible options and possible solutions?
Its very possible and there are many aftermarket kits out there. Or you could use the OEM setup from a Canadian car if you wanted too.
cmesurf
Yes.
Ok thanks, I'll search for the part number for the kit unless you know the part number. Thanks
SteveTheTech
Car: 15 Nissan Sentra SR
12 Infiniti G37x Coupe
-Formerly-
05 Mazda 6 L3 Sport
95 Infiniti J30
94 Nissan D22
Thanks
The DRLs have almost always required operating the high beams at 1/2 electrical load (when in gear/parking brake off). Since the new Gs use the bi-valve style projectors so that 1/2 is "normal" headlights the DRLs have been moved to the fog lights. I have not seen the actual DRL on a modern G (this far south we rarely do) but I am going to wager a bet that the BCM is different from USDM and Canadian Market cars, both of these devices are controlled indirectly via the BCM, I do not know if activating the BCM alone will get DRLs to work but it might also require a new IPDM.
Getting the fog lights to activate without the headlights on should be pretty easy...is that what you are looking for?
cmesurf
Thanks
Yes: I would like to "activate the fog lights without the headlights"
Thanks Steve
Return to “G37 Convertible Forum”
