Hi,
I have been having problems with my 1992 Nissan 300ZX Twin Turbo DRL'S for years now. When I start the car, both DRL'S come on & then several minute later the passenger side fails & the driver's side goes twice as bright as if it was on high beam when it's not. I replaced the DRL module with a used one & the same result. I am now honestly fed up with trying to figure this out. I realize that the DRL & the high beams share the same bulb. Could anyone please tell me if I disconnect the DRL module, would this completely disable my DRL'S yet allow my high beams to work properly? If you think this will work without any further problems, please advise.
Thank you,
Mark Boddy
( mboddy007 @ gmail.com ) Please email me directly as I rarely check this forum...
Thanks
