Day After Dyno...
Chaos the Xile
Car: 1974 Datsun 260Z
I went to have my car dyno'd last night and after 4 pulls and 10PSI later my RB25 setup dyno'd at 427WHP, 378ft,lbs. Then a problem occured... On the last pull the timing seemed to jump up to 23 DEGREES?!?!?!?!?!?!? Don't know the cause of it yet, but there is a weird whining noise coming from the cam cover... so hopefully just the belt stretched... who knows? Just thought I'd give ya'll an update...
Also have a few parts questions too:
1. N1 Oil and Water Pumps - I have checked Taka Karia, Top Hats, JGY, Phase 2. Does anyone have other website that I can order these for for less than $300??2. Jun Crank Collar - LINK to a site when I can purchase one, S1 RB25.
Thats all, new parts dyno graphs coming soon...
l0nestar
Car: 1993 Nissan 250SX
2004 Toyota Altezza
1963 Chevy Impala SS
1. No. $350 appears to be the going price that I have seen for the N1 on reputable sites.
2. No. Nengun? I thought a place Stateside had some though..
PS, what timing belt did / do you have?
Stealth-Z
Car: 1991 300ZX
Here is a place to get a N1 Oil Pump. They have other factory RB parts as well.http://www.nismoparts.com/catalog/?section=756
This is where I got my JUN collar. Which was finally installed last week after a few months wait!https://rhdjapan.com/shop/cart...p=422
Modified by Stealth-Z at 7:59 AM 12/2/2006
Carl H
23 degrees is about right for wot pulls, just means its on a diffrent part of the map.as for 427 whp on 10psi, that i find hard to believe...that dyno is reading WAAAY high
Shocker
Car: 89 240sxHB rb26/30
he is running a 1.06 A/R 35R....
RB20DETodd
Car: 92 Nissan S13 coupe SE RB20DET
Shocker wrote:he is running a 1.06 A/R 35R....
10 psi
Chaos the Xile
Ok I didn't check nengun for part, also as far as the boost the AVC-R is going bananas, my tuner or I can't figure it out we were trying to get it to run constent boost, it was running high boost at like 1500-2000 RPM... I'll get the specifics.
ALSO: The Whole Head is STOCK! Belt and all.
Carl H
lol, i still dont believe it.35r with a 1.06 ar is going to be laggy as hell, and will need more boost to crack that much power...also dyno would help as with an ar that large he would have to be revving to atleast 8k to make power and stock rb25 cams are poo that high.
Shocker
post your graph... im sure you will be able to see the spikes in power with boost spikes.. Also.. this doesnt seeem too far off, LNEUMUP from SAU was making 498 whp at 18 psi with the same turbo... standard everything...
Chaos the Xile
hard to believe its true, as soon as I get the graphs they will be up! An we were revving it high too.
Carl H
with an ar on the turbine of 1.06 there is simply no way you are at full or 'high' boost at 1500-2000, its physicaly impossible.i dont get 10psi on my 30r with a .63 ar till AT LEAST 3.5k.
Chaos the Xile
Look man I dont truly know what the issue was this is just what my tuner was telling me, I'm not as well verse in this like you are when it comes to ever aspect of the car, so when I get the right answer and the results and what happened I will let you know, so I can show you the power is real also the problems...
kjlindgr
My daily driver has 17.5:1 compression and runs 20PSI all day long with boost hitting around 1500RPM...Duramax powaa!!
But about the whining noise. I've heard timing belts making this noise many times before...sometimes even brand new ones. I'd check it and replace it if it hasn't been done recently.
Sky80
Car: '92 240sx Fastback
I dont think he was saying he was hitting boost at 1500 rpms he was saying that the AVC-R was already set in high boost and they couldnt figure out why...
Chaos the Xile
I will be replacing parts on the motor cause thats just my luck, the AVC-R was acting a little strange for some reason it would just shut itself off it seemed... idk whats wrong with it my car is just cursed!
Carl H
no sounds like poor wiring and shortcuts taken, never a good thing when doing a swap.
Darius
Car: RB25DET S14 - 665 WHP (SOLD)
Hey Chaos, do you have a copy of the dyno graph that you can post? I'm sure there are a lot of people that could spot some issues simply based on what they see. I, however, am not one of them
Chaos the Xile
YEah they are on my tuners Laptop so as soon as I get them from him they will be posted
Tictakman
Chaos, here is ur gt35r...
Compressor: T04S housing (4" inlet, 2.5" outlet) 56 trim .70 A/R , flows 65 LB/MIN
Turbine: T3 inlet, 3" outlet (V-Band) 84 trim .82 A/R
hows it runnin now? the avcr, did you fix that problem?
Zak
RB_Dreamin
Chaos the Xile wrote:YEah they are on my tuners Laptop so as soon as I get them from him they will be posted
Didn't know it took this long to photoshop a dyno plot.
Carl H
lawlz!
Chaos the Xile
I still do not have it!!! The car is running fine now, It is hitting 13PSI, I dont know what the hold up is, sorry again for the long wait!
