Daunttless »
https://forums.nicoclub.com/daunttless-u116.html
Wed Sep 04, 2002 9:19 pm
I don't have an opinion, all three are great motors. Personally I prefer the SR or CA, I'm not much of a KA guy but it works for a lot of people.
Theres positives and negatives to each one, and it really depends on your personal preference, what kind of goals you have, and most importantly how much money you have.
Basically, you're not going to get away with any of them for under 3,500-4,000 unless you do the work yourself. A SR swap will cost about 4,000, a CA swap will cost about 4,000, and a KA turbo swap will cost about 4,000.
Of those "basic" swaps, the KA will be making the most power at 235rwhp, but it will take a lot of work to get it past that ( go ahead and argue KA guys, but, it will ) and you have to make sure your engine is in good shape before you do it, which can include a fairly pricey rebuild.
Next up for "stock" power would be the SR, its pushing about 185 to the ground after the swap, 205 flywheel. Its somewhat faster than a stock KA. It will cost you the same, but for every bit you spend after this its the "cheapest" way to 320-350 rwhp, with bolt-ons you can achieve it. However, past that point it starts costing you a lot building up the internals and replacing everything, resleeving, new rocker arms, rocker stoppers, valve springs, blah blah blah. But to 320-350 rwhp its great, and its as cost effective as you'll get.
The last would be the "stock" CA18, its pushing about 155-160 to the ground, 175 flywheel, however I suggest putting at least a S13 turbo on it when you swap it, but it will cost you like 100 or so more than the SR20 swap, however you'll be pushing like 175-180 to the ground. However, in stock trim its not that much faster than a stock KA. People can never seem to fathom this, but the thing you have to understand is that the SR and CA won't drive like the KA offboost, they drive like RWD non-vtec hondas. They are 1.8 and 2.0 liter engines, they aren't putting out much power without the turbo. Therefore, when you're offboost all that time you're only moderately faster than the KA. However, to get to 500 horsepower with the CA you need only put in some forged pistons and a metal headgasket while you're there. : ) So past 350 rwhp, the CA starts to become the more price effective option. However, you always have the offboost downfall of it being a 1.8 liter.
So thats that, if your KA is in good condition and you never plan on doing anything again, then go for the turbo setup. If you only want up to like 350 horsepower pretty easy, go with the SR20, also pretty much everyone carries performance parts for them now. If you want 500 horsepower, you know you want 500, and you want it right away and you have all the money, go CA, its nice.
However, it really all boils down to the three things at the beginning, its however you want to do your project, there is no right answer no matter what people tell you.
Enjoy your day and let me know if theres anything else, maybe I'll make this a sticky so I don't have to keep answering it. : )
