sublime187 wrote:Given the wintry conditions ahead, I've boiled it down to the Yokohama YK520's or a set of ContiExtremeContacts.
Then I would say you have two strikes on you.
For "wintry conditions", a car or even an AWD vehicle needs winter tires. "All season" is a marketing euphemism that really means compromised summer tire and not very good winter tire.
One needs to understand that good performance and long wear are mutually exclusive.
Lastly, the tires are the only part of your car under normal operating conditions in contact with the road are your tires. If you skimp here, nothing else really matters how good it is.
By the way, just in case you did not catch it in the post before, the YK420, the YK520 predecessor, is known to have failed catastrophically (that means blow out at highway speed) on a G50. Others have had DT replace the YK420 at DT expense because it was so bad. Why you would want to subject yourself, your car, your passengers or other drivers to that risk is dumfounding.
