jump »
https://forums.nicoclub.com/jump-u135487.html
Sun Jun 07, 2009 6:09 pm
Its a hydraulic clutch and has a master cylinder on the firewall in front of the driver and a slave cylinder on the right hand side close to the transmission case...since you are probably driving on the wrong side of your vehicle, the locations may be different...your local parts store should be able to provide you with replacements for either or both (slave & master) of the items and then it is a matter of bleeding the line...
good luck down there, mate!
