datsun nl320 front wheel bearing
1962-1965 Datsun L320 and NL320 forums - The truck that started it all in the US. All 320-specific topics and discussion can be found here.
whosdatsun
Car: 1963 Datsun nl320
recently pickep up this datsun nl320 and the right front wheel bearing is bad. took it apart to find the inner bearing damage. online and at the parts store it called for 30206 inner and 30204 outter (national bearings). after removing hub found p/n 30304a and 32kb02. do i have the wrong hub?
Li'l Truckie
Car: 3 x '65 PL 320
1 x '64 PL 320
1 x '63 PL 320
1 x '62 PL 320 - parts :(
1 x '60 PLG-222
and many more Datsuns from 48hp to over 500hp
Nope, you have the same 6 lug hub like the rest of us. Unfortunately 30206 does not work, its a little to small. So regardless of who say what on eBay or parts store, 30206 just doesn't work. The outer bearing is a good part number and works.
32KB02 is the orginal bearing by Koyo, but they do not make it or stock it. I think it is still a good part number, but they were clueless about it.
Just don't throw it away like I did. I thougth 30206 was a good number only to find it was not and that the trash had already been picked up for the week.
One option is to go with 30206 and get a larger race with the same inner diameter as 30206 and with a larger outer diameter for the hub - or so I am told. I just have not investigated this one.
Option two is to purchase a set from a guy in Washington - I just need to find his web address. Blue something....
whosdatsun
thanks lil truckie, back to the parts store. i think the were abable to match the ones that came out. unfortunate i had to learn the hard way. ordered by year make and model. book says the ones that came out were for earlier 59 datsun
Li'l Truckie
Car: 3 x '65 PL 320
1 x '64 PL 320
1 x '63 PL 320
1 x '60 PLG-222
Yip, '59 or '58, same hub was used for about 10 years. I think they finally changed to something else for the 521 with the L16, just don't quote me on that one. A good question is could a hub from a 620 or 720 will work on the 320 - unknown is if this hub and bearing will work on the 320 spindle? hmm....
If they match it up please let us know. My local parts stores were not to helpful. I'm heading to downtown KCMO next Monday and will stop by Sterling Bearing, something close to that, and see what they say.
Will have your link later this evening. Putting the shift linkage in my '64. If I had an oil filter I could try to start it, but I don't and can't.
Andy
Li'l Truckie
Car: 3 x '65 PL 320
1 x '64 PL 320
1 x '63 PL 320
1 x '60 PLG-222
Here's the link to Blue Hand Inc for the wheel bearing spacer. Got the info from Steve in OK -
http://www.bluehandsinc.com/
Just scroll down the page a little and you will see the spacer.
whosdatsun
Thanks Andy
whosdatsun
If this info could help. Went back to parts store and match inner bearing 32kb02 to 32206 and outer bearing 30304a to 30304. Both national bearings.
deerio
Car: '63 L320
So just to clarify:
The National 30206 INNER bearing DOES NOT work but 32206 (which matches 32KB02) fits?
and
The National 30204 OUTER bearing DOES work but so does 30304 (which matches 30304A)?
Li'l Truckie
Car: 3 x '65 PL 320
1 x '64 PL 320
1 x '63 PL 320
1 x '60 PLG-222
I have a hub in the bed of my truck and can easily verify this today. Wow this is some good news.
Tracking 32206.
Great news
Andy
Conner
Car: SRL31101633
1964 L320
Let us know what you find out!
whosdatsun
Sorry, no it does not. The race fit the hub but the bearing did not fit the shaft. Sorry for the wrong info. Back to parts store
datsuns4fun
Car: 1964 NL320
1965 410
1969 2000
here is my post from a couple of years ago..
"Found some of those elusive inner wheel bearings NSK 32KB02. www.universalbearing.com have 5 left in inventory. You will have to find a local distributor as you cannot purchase directly from Universal. Hope this helps someone out."
Hopefully they still have some of these around
whosdatsun
Picked one up on eBay from Filippos Tsakiridis. It was an koyo 32kb02 works great
whosdatsun
After Weeks of shopping, I think it's impossible to find replacement. Only option is new old stock or change suspension. Any help with posting my pic pm me. I want to share what I'm working on
Li'l Truckie
Car: 3 x '65 PL 320
1 x '64 PL 320
1 x '63 PL 320
1 x '60 PLG-222
whosdatsun,
Here is how I post pics -
hit Img above on the menu across the top.
Go to your web site for where you have up loaded your pics - sorry cannot upload straight from you home computer.
I use flickr
On flicker find pic/photo
Click on share image
Select size
Click on HMTL and copy the way to long url for the photo -
-- <a href="https://www.flickr.com/photos/113742723@N07/11827232196" title="Wow, now isn't that looking nice! by Li'l Truckie, on Flickr"><img src="https://farm6.staticflickr.com/5510/118 ... a2c5_s.jpg" width="75" height="75" alt="Wow, now isn't that looking nice!"></a>
The part you want/need of whatever all of this means is what I have bolded, so from the https://farm6 to the end .jpg all that computer speak before and after can be deleted or simply not copied over.
So you can paste the entire url for the photo in between the Image and delete what is not necessary or only copy the https://farm6 to the end .jpg on the flickr photo page.
Or at least that is how I work my photos and it looks like this for micro small -
or this for large ++++
hope this helps.
Andy
Return to “Datsun 320”
