datsunexcells »
https://forums.nicoclub.com/datsunexcells-u110523.html
Wed Dec 31, 1969 5:00 pm
agphysics, If you post the dimensions and number of teeth on your flywheel, it would probably be easier to determine if someone has one that would fit your truck. Bolt hole sizes and bolt circle diameter would also be helpful. If you have a source for one, that's great, but the information would also be helpful for others that might need one. Some parts enjoyed universal use in some auto makers product lines, so the flywheel for your 320 truck may be the same as the one used in other models and model years. John
