Ted Heaton »
https://forums.nicoclub.com/ted-heaton-u240184.html
Wed Dec 28, 2016 7:02 pm
Datsun 320 door weatherstrip.
The Miracle NL320 Fit!
Here is a nice replacement if your tired of that rotten 50 year old weatherstripping on your 320.
A local truck brother, Joe E., did a lot of searching for usable newer parts when he restored his L320 a few years ago.
He found that the rear door rubber from the Volvo S80 models (1998-2006) fit the 320 body seams really good.
He got rubbers from a junk yard that were like new, no one uses the back seats, and one rubber does a L320 door with some extra.
It is modern weatherstripping with nice felt like material on the inside.
The mounting groove is moldable and can be squeezed together for a good, no glue, fit.
The weatherstrip is thick so you have to modify the aluminium trim scuff plate or cut the inner rubber back to fit the plate or leave off the scuff plate.
He got me some and I just got around to installing it on my NL320 and AMAZINGLY it is correct length for an NL320 door opening.
NO cutting.! It fits perfect! I could not believe it.
I wanted to keep the scuff plate so I flattened out the curved top section to cover more of the thicker weatherstrip.
The hardest part of this job is cleaning off all the ancient glued on weatherstrip and
removing the rusted screws that hold the aluminum scuff plate The screws threads are exposed under the floor pan
and with lots of heat I got then all to back out without breaking any.
An interesting discovery was that the NL320 scuff plate is shaped differently than the L320 plate and it is 2 pieces. It seems that Nissan did not make a longer 1 piece plate but added a small 6" section at the rear to make up for the longer NL320 door and body opening. It is shown in the parts catalog.
