To what is available in after market parts
Here is the info on the 90 degree angle hose
Hose - Radiator Upper
Part Number: NBH 7446
Product Line: NAPA Belts & Hoses
IMPORTANT INFO: @Cut to Length@
Here's the round/circular 90 degree hose. I like this one the best, but its also the most expensive of the top hoses
Part Number: NBH 7309
Only one I could find for the lower radiator hose -
Hose - Radiator Lower
Part Number: NBH 7543
Here's the link to page 125 of Victoria British's MGA cooling system for the lower radiator hose elbow. Your local hardware store may have something similar -
http://www.victoriabritish.com/icatalog ... x?Page=125
See part number 14-763. Other parts on this page also work, like the studs, thermostat gasket, thermostat blank, hoses and hose clamps.
Here's the info on the water pump -
Water Pump - Remfd
Part Number: WP 571198
Product Line: Remanufactured Water Pump
IMPORTANT INFO: w/o Fan Clutch
Here's the more expensive water pump
Water Pump - New
Part Number: TFW 42324
Product Line: Tru-Flow Water Pumps
Radiator cap and thermostat are just the regular type parts that vary depending on the pressure and temperature.
If something is missing let me know and I'll do some research,
Li'l Truckie
