evildky »
https://forums.nicoclub.com/evildky-u13100.html
Mon Mar 17, 2008 5:59 pm
could be a stuck or bad AFM, bad fuel pump, FP relay, injector relay, distributor or even the ECU, first things first, do you have voltage at the fuel pump? Is the AFM flapper stuck?
