Datson/Nissan 720 4x4 Gearboxes
1980-1986 Datsun 720 forums. All 720-specific topics and discussion can be found here.
pirate77
Car: Nissan/Datson 720 4x4 King Cab
G'day.
I am rebuilding a 1985 Nissan King Cab 4x4 petrol tray back and using a Datsun 720 tray back 4x4 with a SD25 diesel motor.
Can anyone tell me if the diesel motor will fit onto the petrol gearbox, both are 5 speed boxes.
I have not worked on Nissan/Datsun vehicles before and any help would be appreciated.
Thank you.
Clive.
waynosworld
You have to use the diesel transmission front case with the diesel engine, the starter is on the left side on the diesel engine, and the gas engine has the starter on the right side.
Are you putting the diesel engine in the gas engine frame, I ask because the diesel engine mounts differently than the gas engine, the easiest way is to cut the diesel frame mounts off the diesel frame and mount them on the gas frame after you cut the gas mounts off, you slip the diesel engine/transmission into position and mount the transmission on its mount, connect all the mount hardware from the diesel frame to the motor mounts, then drop the engine onto the frame making sure the diesel mounts rest properly onto the frame, then tack them into position, then remove everything and weld them to the frame.
Is this the Clive I know in Australia, I am wayno.
I have a few Datsun/Nissan diesels, my 521 kingcab is a SD25 diesel.
I forgot to mention that you will need a diesel engine 4X4 oil pan, they are different than the gas engine pan, so you will need to find one unless it already has one.
Desert Rat
Car: 2014 370Z M6 Base Coupe
2017 Frontier 4.0
2007 Dodge Ram 2500 Cummins Quad Cab 4x4
1977 F150 4x4 Shorty BUILT
2008 Boulevard C90T
Previous owner of a bunch of Nissans
I would love to have that motor in my 98 Frontier....
Return to “Datsun 720”
