data loggin Oil temp, pressure , water temp on a OBDII ECU
nismo1003
Car: Ka24de
I have a 98 KA24DE Turbo, i want to data log the water temp, Oil temp and Oil presure on my Boost control , what's the voltage range on the stock sensor ? 0-5V? what's the conversion to the tempture and pressure like at what voltage for 30psi..something like that.. or should I add the sensor to it, i believe there are no Oil temp sensor in a KA, if so should I tap the sensor to the oil pan? I'm running a Oil cooler, can I route it before the cooler to get the accurate reading?
ILikeMy240sx
Car: SR Power
As for there being no oil temp sensor for KA you are right. There is only a dummy (useless) oil pressure sender.
I would put the sensor somewhere after the cooler since that is the temperature that the engine is being exposed to. Alot of people use either brass fittings on that stock oil pressure sender or use sandwich adapter that goes between the oil filter and the block. Since you are looking to do both oil tem and oil pressure and have an oil feed line I think a sandwich adapter might be a better route for you.
nismo1003
Car: Ka24de
are the stock oil pressure sender only activate the switch when there are not enought pressure in the system ? like on and off switch?
blubottlemax
Car: Cars, aviation, snowboarding
It only comes on when there is less than 5 psi, +/- 1 left. By that point, your motor is already toast.
skatanic28
Car: 96 240sx
heres the coolant temp cal that im using right now. you are on your own for oil temp and pressure, as they are not stock sensors.
nismo1003
Car: Ka24de
thanx man..I need to get that data into my power meter.
