Dashboard wiring(by ECU)
Zushi
Hey, on the heavythrottle information for the harness that goes up to the dash board(near the ECU) it says to put black to ground. well on that harness there are 3 black wires. 1 solid black, and then 2 other blakcs with silver bands. the site says to connect the black to ground, im guessing its the solid black but i know the others are grounded too.. any ideas?
float_6969
W/Nissan's black wires will 99% of the time be a ground wire. If you're worried about it, just connect them all to a ground. But IIRC 2 of them are for the check connector anyway.
Zushi
hrmm, ok...i fixed the code 43 by adjusting my TPS to the right setting. i turned my key to "on" and the ecu read a code 55(no malfunction) however once i tried to start my car, it read a code 21(ignition signal). i traced it to my power transistor...tested it for continuity and its bad. anyone have a power transistor for sale? heh
boost_boy
$60 shipped!
Zushi
cool, you do paypal? whats your email? thanks
boost_boy
I paypal and am confirmed at : [email protected] which is also my email address.
float_6969
NICO loves Dee
