Dashboard lights blackout when brake applied
A home for 1983–1989 300ZX owners!
akaNYr
Car: 1986 300ZX 2+2 NA
I just bought an 86 300ZX 2+2 A/T NA. Every time I apply the brake the whole dash goes out for a millisecond then comes back on. My whole dashboard is digital. The other problem, possibly related to the blackout, is my battery drains super fast. The alternator is new, previous owner replaced it a month before I bought the car. How do I test for the short & where do I start? :confused:
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
Aftermarket radio? I've seen a lot of bad stereo installs incorrectly ground to the illumination circuit.
akaNYr
Yep previous owner put in JVC digital detachable face stereo. He left wires coming thru firewall with clear fuse box just hanging by the battery. He also left 2 RCA jacks & a bare ended wire under the rear carpet touching the metal! It's probably what killed the battery within a few months, I had to go exchange it. Could bad radio install also be causing my volt gauge to be pinned to the top, above 16 volts, while the car is in parked and idle? BTW thank for your reply.
evildky
06 Nissan 350Z GT
Never seen a voltage gauge do that, but removing all the aftermarket wiring sounds to be a step in the right direction.
Desert Rat
Car: 2014 370Z M6 Base Coupe
2017 Frontier 4.0
2007 Dodge Ram 2500 Cummins Quad Cab 4x4
1977 F150 4x4 Shorty BUILT
2008 Boulevard C90T
Previous owner of a bunch of Nissans
check grounds too. Dash lights and tails are typically on the same fuse in a Nissan.
Return to “300ZX (Z31) Forum”
