Dashboard crack
60fireflite
Car: 2000 I-30t, 2010 M35
Well, more accurately, the surround of the upper dashboard 'glasses' compartment (directly above the analog clock). How do I remove it in order to replace it?
Thanks in advance!
MaximA32
Pics? It's hard to imagine where precisely you're talking about.
60fireflite
Not sure how to post a picture. There is a compartment on the top of the dash. The lid is hinged near the windshield and there is a crack in the plastic between where the hinge posts go through. This plastic piece ( I called it a surround) is what I want to replace. That help?
loystock
Car: 10 Honda Pilot
97 Infiniti Q45
03 Infiniti Q45
97 Infiniti I30
06 Infiniti M35 Sports
04 G35 & 99 I30-RIP
Start on page BT-30 from the link below and go from there.
http://www.nicoclub.com/FSM/i30/2001/bt.pdf
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
You need to remove the vents and HVAC/radio surround (all one unit). They're not screwed in, just attached by spring clips. Pull out on it and it will come loose. One good way to pop it loose is to pry with a screwdriver wrapped in a towel.
Once the vents are out of the way, you'll see the screws holding the upper clock trim (which is the same piece as the glasses surround). Remove those and the whole compartment will lift out. Take care not to tear the wire out of the back of the clock when you lift the piece out.
60fireflite
Thanks! I'll try this weekend.
MinisterofDOOM
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
I just remembered I have this image showing the clip and screw locations for clock removal:
hotboyses
Car: 03 Infiniti I35 black on black with factory Infiniti chrome rims, 8000k HID fogs, Clear sidemarker lights with with LED's, LED's through out cabin. Much more to come...
Thank you very much.
hotboyses
MinisterofDOOM wrote:I just remembered I have this image showing the clip and screw locations for clock removal:
Hey do you know what size bulb it takes?
loystock
Car: 10 Honda Pilot
97 Infiniti Q45
03 Infiniti Q45
97 Infiniti I30
04 G35 & 99 I30-RIP
I believe P/N: 28529-0P00 is the bulb for the clock. You can contact IoS (Infiniti of Scottsdale) - "infinitipartsUSA.com" to verify. It's @ $3+ each but shipping is $9. You can also try "Autolumination.com" from the link below and look (scroll down) for a "Neo-wedge LED" and try to match the dimension of the bulb you are looking for.
http://autolumination.com/74.htm
A cheaper alternative maybe Radio Shack Microlamps, P/N: 272-1092. It's rated at 12VDC, 60mA, 0.15 MSCP brightness with 1" wire length. At <$2 a pair, it's a huge savings if you can make it work. Refer to link below. This bulb can be used in some of the backlighting requirements of Infiniti/Nissan cars. You may have to be creative during the replacement procedure - unwind the original bulb from socket, insert new bulb and wind leads, then cut off excess length.
http://www.radioshack.com/product/index ... Id=2103780
NutriaforBreakfast
Car: Nissan Maxima 1995 VQDE engine
Since i am cheap i dont turn the backlighting all the way up for the speedometer-odometer
so the bulbs last longer
