Dashboard brake light
All things Altima Coupe.
KilaDragN
Car: 08 Altima Coupe 2.5 MT
Hey guys, not sure what the problem is, but sometimes when i accelerate hard, my "brake" light on my dash comes on for a couple of seconds and turns off. It just started happening recently. i noticed it mainly does it when i accel on an uphill. any ideas what it could be? thanks in advance.
srwong
Car: 2009 Altima Coupe 3.5 SE CVT
brake fluid?
SHIFT_COUPE
Car: 2014 Infiniti Q50 AWD
Yep, brake fluid. Check the level, its probably slightly low. When you accelerate or drive up a hill, the fluid moves past the sensor.
DJ_B_Easy
Car: 2017 GMC Sierra All Terrain X
I had this problem, started happening more and more frequently. Ended up being the master cylinder. Covered under standard warranty to 36K.
2008AltiCoupeDan
Car: 2008 Altima Coupe 2.5s - Gone, 2008 Subaru WRX Premium - built
could check your ebrake too - maybe its one click up or w/e- but i agree- if its up a hill - 9/10 times its fluid lol
Ranga14
Car: Boosted 08 Altima Coupe 3.5
I get this issue but only when taking turns aggressively and then trying to accelerate.
DJ_B_Easy
People if you are under 36K go get this checked out. The master cylinder would have been about $800. Check your fluid, if its not that Id go straight to the stealership.
KilaDragN
Brake fluid does look a bit low, its at the MIN line. im already at 40K miles on my car. soooooooooo yeaaaaa. Thanks everyone. hopefully that'll solve the problem. never knew there was a sensor for that.
AltiCoupeDan: definitely not the ebrake. it was the first thing i checked. when u pulled it up slightly b4 the first click, the warning screen pops up on ur dash.
sorry it took awhile to reply. i dont get holidays off, sucks working in the food industry. need a change in career LOL
Hussain
Car: 08 Altima Coupe 3.5se CVT
99% chance it IS the brake fluid. some of the older members remember threads like these. this is like the 5th thread about it and every persons problem was solved by adding some brake fluid (including myself). so put some brake fluid in it and the problem should go away
Viper5000
Car: 2009 Altima Coupe 3.5SE/6MT
refilling your fluid will make the light go away...but check out your brakes, because the fluid only goes down for one of 2 reasons.
a leak,
or most likely worn pads.
soxypoo
Car: 2008 Nissan Altima Coupe 3.5 ( gone )
2010 red G37X w/sportpackage
2012 sentra ser spec v loaded
i have the same problem ... so what typeof brake fluid do u guys use ??? brand ???
srwong
soxypoo wrote:i have the same problem ... so what typeof brake fluid do u guys use ??? brand ???
the kind the cap says.
Viper5000
the kind the cap says. dot 5
definitely dont put 5 in your reservoir.... the cap says use DOT 3 only.... but I just did my brakes and put in DOT 4. you can put any DOT 3, 4, or 5.1 and you should be good.
srwong
yea my bad. i was talking to sum1 bout big 5 and typed 5, while i was thinking 3. lol
Hussain
Viper5000 wrote:refilling your fluid will make the light go away...but check out your brakes, because the fluid only goes down for one of 2 reasons.
a leak,
idk about that. my light came on and I put some fluid and the light went away. I havent replaced my brakes and the light hasnt come on since. it happens to pretty much everyone. I think after like a year or so of owning the car it comes on. I put some brake fluid and it hasnt come on since then. I've owned the car for 3 years and 4 days and have almost 33,000 miles on it.
MikeisSUPERBAD
Car: 2011 Nissan Sentra SE-R
sounds like i have the same situation... my car is almost 3 yrs old and i have just over 30k miles and the brake light comes on usually after a acceleration and goes away after a few seconds... i will be wasting my time on saturday morning at the dealership ughhh
srwong
MikeisSUPERBAD wrote:sounds like i have the same situation... my car is almost 3 yrs old and i have just over 30k miles and the brake light comes on usually after a acceleration and goes away after a few seconds... i will be wasting my time on saturday morning at the dealership ughhh
check brake fluid first
Ranga14
Refilling brake fluid is easy guys, no need to go to dealer unless it's something more serious.
I used Dot 4. All it means when it goes up is that it can withstand higher brake temps.
Mattv609
Car: 2009 Nissan Altima Coupe 3.5 SE V6 Azure Blue
It's deff the fluid I had same problem and hasn't Happen in a while but Brian (lbc) told me that are cars tent to leak it... But fill that bitxh up n u good
