dash wiring
fallen180sx
Car: 90 Sil80
does anyone know what wires are for the engine temp and gas? the guides i find diagrams for are only ac relay, tachometer, speedometer, ignition start, ground and water temp signal. thanks..
NeedCAforS13
Car: CA swapped S13 coupe
engine temp = water temp
gas comes from the back of the car therefore you don't need to re-wire that. its already wired correctly from your body harness (does not go through the ECU) the only ones you need are the ones you found.
Sean
fallen180sx
Car: 90 Sil80
alrighty thanks ca, btw you got a nice a$$ engine! got anymore pics? what kinda blue is that?
float_6969
It's called, "Big Ghey Blue"...Hehehe, JK Sean, you know I'm jealous!
NeedCAforS13
its that metallic blue spray paint you can get at Discount/Advance Auto Parts. The two step stuff. It has a silver base coat, and a semi-clear blue top coat. Looks pretty good, but it kinda ran in some places. Doesn't look quite as good in person
and I have tons of pics, just haven't uploaded them to http://www.ca18det.org yet. there's afew at my old cardomain site http://www.cardomain.com/id/needcafors13
Sean
