dash warning "other"
Discussion of Infiniti's amazing (and underrated) sport-luxury crossovers, the EX35 and EX37. For 2014, the EX series will be renamed QX50, in line with Ininfiit's new naming conventions.
apeg
Car: 2008 Ex35
my dash warning "other" just went off... ive googled and check the manual and cant see what this warning is associated with? its a manually set item, I can go in and change how (KM) it fires.
Its in the same location that tells you when you need an oil change or new tires...
ideas? thanks,
-aPeg
XIS
Car: 08 Infiniti EX35 RWD
17 Infiniti QX30 Sport
page 2-23 of the manual...
4. ªOTHERº indicator
This indicator appears when the set time comes
for replacing items other than the engine oil, oil
filter and tires. You can set or reset the distance
for replacing the items. (See ªTRIP COMPUTERº
later in this section.)
Return to “Infiniti EX35 / EX37 and QX50 / QX55 Forum”
