Ace2cool »
https://forums.nicoclub.com/ace2cool-u95120.html
Fri Feb 27, 2015 8:46 pm
Oh wow. Just for terminology's sake, these technically don't have a harmonic balancer. The pulley has a built in dampener, which isn't really the same thing. These are actually very balanced V6s. If it's toast though, I'd go ahead and upgrade to an underdrive pulley and use an overdrive water pump pulley. Must not have been torqued properly though. I've never seen one of those crank bolts come loose. Make sure the timing gear didn't walk forward at all too, cause a weak timing belt is sure to spell doom.
