slownslurious »
https://forums.nicoclub.com/slownslurious-u29303.html
Tue Oct 31, 2006 7:14 am
the fuel light is generally worthless because when it turns on you have about 5 miles to get some gas at most. usually less. If your fuel light comes on then your fuel is too low. you should generally keep enough fuel in the tank to cover the pump (for performance reasons and for fuel pump cooling reasons).
but yeah I mean its a pretty quick check, pull out the cluster, check the bulbs, chances are good they are bad, clean and lubricate the plugs that go into the cluster. that would probably fix it.
