Dash Removal on a 03 M45
adoshi
Hey guys, this is my first post, and hopefully i'll be able to get some help!
I am trying to remove the dash of my 2003 M45 to gain access to that area because something is rattling. What is the easiest way to remove the dash?
Thanks
auditech10
Car: 03 M45
The entire dash panel?
Bag302
You can access a fair amount of the dash by removing the 'info center'. You can carefully pry it out.
You can also get to the instrument cluster if you start by removing the small piece of plastic around the ignition. (just pull from the top)
I'd recommend getting your hands on a service manual CD as well.
