Socaldiablo »
https://forums.nicoclub.com/socaldiablo-u163627.html
Thu Nov 17, 2016 10:41 am
As a follow-up to my original post on this topic, I successfully replaced that upper blend door actuator motor last weekend and there were a few things I did to make this happen just so that others on here with the same problem can gain a bit more confidence on how to replace their failing actuator motors. I DID NOT need to remove the dashboard! What I did do is disconnect the battery, then removed the glove box assembly and black cover to the evaporator for a bit easier access to where the actuator sits. Now, here is the part that made this work for me. I also removed the shifter knob, center shifter assembly, radio/HVAC trim bezel, and removed the radio/CD head unit. Removing the head unit was key as it allows you to see the actuator. I still had to reach my hand over the evaporator to remove the screws and the actuator itself but being able to see where the screws were and how the door arms line up to the actuator was absolutely crucial for me. I did have to go out and buy one of those small flexible LED flashlights ($6.00 at Home Depot) so that I could verify that the door arms lined up into the new actuator correctly. If you don't get these arms lined up right, the entire job would be a waste of time. Shining that flexible light inside the tight spot where the actuator sits allows you to see how the black arm lines up. The white arm is closer to the front and since it's white, you can easily see how that lines up without the flashlight but the black arm that sits further back blends in with the black background and you cannot see it with some added light. I got everything put back together, reconnected the battery, started the truck up, and there it was, the sweet sound of silence! No more clicking. I then confirmed that the HVAC was working properly by cycling through the various A/C modes and everything worked as it should. This job sucks but I saved probably on the order of about $400-$500 in labor costs.
