Dash plug wiring help
RoyalFortune
Car: 1990 Nissan 240SX
I would really appreciate some help. I have a 1990 240 that originally had a SOHC ka24 and auto transmission. I replace the KA with a early redtop sr and 5 speed swap. The issue I have is the dash plug. There is the original little white plug above the ECU and the one that was on there does not match the wire colors on the sr harness. If anyone has a diagram with the colors or knows what color wire match to the sr harness that would be greatly appreciated.
These are the wire colors on this white plug:
BlackWhite/BlueYellow/RedGreen/BlackBlueYellow/WhiteGreen/RedYellow/Green
J14cm7
Car: 95 240sx S14 SR20det
Sounds like its FSM time. Compare the JDM FSM and the USDM FSM side by side and youll figure it out. Search around a little they are easy to find
