slipnfall »
https://forums.nicoclub.com/slipnfall-u4227.html
Tue Nov 02, 2004 3:00 pm
Ok, this is from my '92 FSM(p. EL-6), so it should apply...
Looking directly at the fuse box(under dash), below is the left-side, from top-down(with their current rating(A) and what it powers.
1-15A:Blower motor2-15A:Blower motor3-10A:Heater and A/C4-15A:Cig. Lighter5-20A:W/S washer and wipers6-10A:Rear wiper/washer, pwr mirrors7-10A:HUD control unit,TCU, Radio, Audio, Rear defrog rly,HUD Speedo, ntenae Timer8-10A:Turn sig's9-10A:Meter/guages,HUD control unit,warning lamps,SRS, ant. timer, daytime lights10-10A:ASCD HICAS control unit
On the right:1-20A:Rear defrog2-20A:(same^)3-10A:Int. lamps, radio, audio, clock, warning chime, TCU, A/T control, HUD control,SRS, HICAS control, ant. timer.4-15A:Brake light, shift lock control, ASCD control5-10A:Hazard lamps6-5A:Headlight timer,Retract rly7-10A:Daytime light control8-15A:Ext. lights, glove box lamp, headlight timer, TCU.9-10A:ECM, daytime light control10-10A:Reverse lamp,inhibitor switch,A/T control unit,shift lock control unit,ABS control unit,HICAS warning light.
HTH.
::edit:: You still should[will need to] check that voltage is getting to the wires in the rear of the instrument panel.
