Dash lights went out, need help
hopesfallhxc
Ok i have a HUD gauage cluster,last night when i was driving home the lights that light up the gauge cluster and show my gas, rpms ect. wouldnt turn on. My HUD still works so i kno how fast im goin, just the gauge cluster lights dont work. Im thinking it might be a fuse, but is it a fuse from under thedash board, or maybe a relay? Any ideas of what it may be would be helpful too. Thanks- Shaun
Onizuka
Car: 91 Nissan S13 coupe SR20DET
89 Nissan S14 hatch SR20DE
i dont know how to fix it, but i have heard of the problem before, my freinds HUD radomly goes out and turns back on sometimes on his 91 coupe.
hopesfallhxc
well the HUD still works jsut the lights that light up the dashboard went out. IF the HUD goes out, im gonna say screw it and go analog.
rousie13
Car: 2006 Nissan 350z Track Edition, 1997 Ford F250 4X4
I had this happen to me this past summer. Check your fuses inside the car with a fuse tester. Then if that doesn't work, it's your TCU(time control unit), dimmer switch or a short in the wiring. The TCU is expensive if you buy it form a dealer, but I got mine for $25 from a junkyard. It's pretty much just a trial and error thing, unless you take it to the dealer and have them tell you whats wrong with it.
hopesfallhxc
Thank you, looks like i have some things to mess around with this weekend. sigh.
rousie13
No problem man. Let me know if you need any details on anything.
TheSnail
Car: RB26 powered 93 s13
"Dash lights went out, need help "
Welcome to the club
swtslvrmonkey
Car: 1981 Datsun 310 Gx
me too! well they were otu already when i got my 240, i checked the TCM box and there was a circuit line burned out, so i replaced it,a nd it burned out again, so what could be the problem?
Kiwi_S13
If you installed a new head unit that is 99% of the time going to be your problem. The factory amps need to be bypassed inorder to preserve the TCM unit. Someone should find a good link/write up on how to properly wire a new head unit and sticky it because it seems lots of you guys are having issues with this lately. At this rate there wont be any junkyard TCM's left and everyone will have to learn some very tricky soldering skills or get raped by dealerships. Do a search on wiring the stereo for proper connections.
KyLe
