Hey man, I literally just went through this today.
Okay so you need to find that TCU box, its behind the driver side kick panel, near the fuse box, to the left, screwed into the body by a small metal bracket. If its not there, see if you have a connector for one sitting nearby, because that's the issue, otherwise post a picture of what you have.
Another common problem is that the dimmer switch goes bad, so what you can do in that scenario is jump the left most connectors using a paper clip. Its ghetto, its stupid, but it beats not being able to read your speedo at night...
Okay so with that said, here's what you are looking for:
On the back of the board, this is what typically burns out:
You can try to jump it using a soldering iron:
I did not have any luck with that and ended up just calling a buddy of mine to get a new TCU, I've heard rumors of success but I can't find any evidence. However, I now have dash lights.
Keep me posted and I'll do my best to help you out!
