would the dimmer switch have anything to do with it.....the dimmer has never worked since ive owned the car though....kbflip02 wrote:ok so the green lights in the gauge cluster and clock are no longer working...is it a fuse and if so which one and where....all the other warning lights work too
So months past and nothing?I tried checking the fuse box, and fuses were good. Any other advices?BobWilson wrote:I had the same issue with the dimmer. Mine slowly worked less and less until it didn't work at all.
I found some instructions on taking it apart and using contact cleaner on it. I did that and it worked great. Can't remember the location of that info, but a search may turn it up.
Then it starts getting dirty again and needing to be tapped to work so when taking parts from a local salvage car I grabbed the dimmer while I was at it and that worked great too. And was cheap.
Please describe YOUR particular problem, with the dimmer switch and all of the interior lights that it controls or just only the clock and instrument cluster lights together, which fuses you checked and where they were located, and you may want to start a new thread.bo0gz wrote:Someone please help
