Dash lights out
charat
Car: 1992 Nissan 240sx SE, 2008 Honda civic EX
so i need help here. my gauge lights dont work. the seatbelt light and engine fuel light all come up, but as soon as i turn on my lights, the gauge cluster goes dark. i checked all my fuses and my tailights work.
if you are going to post with:http://www.nicoclub.com/articles.php?id=158162its not the problem. i checked it twice.
are my bulbs just burnt out? =.= i have a feeling that might just be the problem...
charat
bumpo
charat
bump
charat
no one can help me? =.=
charat
20 views and not a single reply...
Razi
Car: Moo
Stop bumping the thread every damn minute.
Spammer.
charat
why do you care? loser.
Razi
Car: Moo
Guess you don't want help.
a**
charat
not from someone who's being an *** the first step in.
IDRFT95S14
Car: 1995 Nissan 240sx SE
its kinda late dood but srly just wait a little longer im sure someone will pop outa nowhere
charat
razi should learn from you. thanks for the encouragement. =]
IDRFT95S14
n waiting------------------------
n wating
charat
yup...
krayzie94
Car: 1989 240sx
Dash lights not working?
I think you should fix that...Sounds dangerous.
BIGTIMER_240
Car: 1989 240SX ka24de
what did you do to it try your dimmer
spooled240
Car: kouki s14
Nico is usually dead at night bro, I'm probably the only one on here right now cuz I just got back from a p0rn crusade....actually just late night homework
sebazztard
Car: 1992 Nissan 240sx rb25det project. 2000 Honda Accord LX DD. 1992 Nissan 300zx NA.
pop out your dimmer switch from the dash and test the wires with a test lamp. you dont state what car you have, but on my 95 you have to remove the trim, then press the 2 tabs in and pull the dimmer switch out from the front. 3 wires, 2 are positive. if you dont have any juice you have a fuse issue or a wiring issue. i couldnt figure mine out so i had to run my own positive wire to the switch (which was the first positive). if you have power to your switch and you still arent getting lights then you have a cluster issue, which could be burnt bulbs or maybe the switch has a bad ground itself. its your only problems at this point i belive.
charat
i have a 240sx s13 chuki. so DOHC. ive tried the dimmer switch. aside from my dash lights working, the speedo is out too...
thanks guys for all your help
amolao
Car: 1989 Hatchback (the first one...) w/ Autech sr20de S15
Check my website, I had a similar problem and it was a bad diode in the cluster. Make sure to check all the other things already mentioned before you go that far.....
charat
oh thanks! ill see if this works since ive tried everything else out. thanks again!
