Dash lights on: ABS, Airbag, Trans.
Omar
Car: cars, computers, fashion, my friends
Hello,
I recently replaced my ECU/ECM on my '94 automatic G20. The ECU is from a '96 automatic G20. The car is starting and driving fine. It actually runs and shifts great. However, the ABS, Airbag, and Transmission lights are all on the dash.
Is it because I put a new ECM in? Is it because its from a different year?
How can I fix it? Is there a way to reset it?
Anyone else experience the same thing?
Thanks,
Omar
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
the 96 ECU im surprised works at all, because 96 is OBDII where 94 is OBDI
gniknave
Car: 2000 Audi A6 2.8 Quattro
2008 Honda Civic EX (Sedan)
elwesso wrote:the 96 ECU im surprised works at all, because 96 is OBDII where 94 is OBDI
I'm betting this is the problem. If for some odd reason it's not, I'd check your charging system. Those lights are a sign of alternator failure in a Q45 (not sure about G20 though).
Omar
Well, good thing the ECU has a full refund.
I will just pick up the car and put in the ECU myself. The shop will charge me alot. I bought the ECU anyways so he wont even warranty it. No biggie.
My question is that is it easy to change the ECU? How do I do remove and install it? What do I need to do?
Please help me.
Thanks,
Omar
Omar
Anyone?
