ricebike »
https://forums.nicoclub.com/ricebike-u5064.html
Sun Jun 18, 2006 6:44 am
been discussed a million gazillion times... lets start w/ this:
ok, u posted 3 different threads that may be all related together... headlight, hud, & this
but you can start by checking this article in terms of no dash lights
is there an aftermarket stereo installed in this vehcile or the original? make sure there's a separate ground wire from the head unit to body chassis & the illumination wires aren't connected to aftermarket unit...
try this for the HUD; i dunno what happened to the pic links in that thread, though
mod: what happen to the pics in this article?
headlight not popping up? did previous owner did that free sleepy eye modification & probably cut the brown wire behind the pop-up switch? you can just yank it off & check. other than that, there was an extensive diagnosing w/ the nissan online tech a couple of months ago... gotta search for it in the archives , i think
Modified by ricebike at 1:00 PM 6/18/2006
Modified by ricebike at 1:01 PM 6/18/2006
