8631z »
https://forums.nicoclub.com/8631z-u274527.html
Mon Sep 11, 2017 3:28 pm
i have an 86 turbo that the dash lights do not dim. the lights go on with the headlight switch but do not respond to the dim buttons. i have taken out the Timing control unit. (not fun to get to) and tested the feed from the light switch and the dimmer switch. they all tested good. im under the impression that the tcu is bad. i just want to make sure i covered all the bases. i also had to replace the digi dash and the voice control as that was failing too.
on a side not the red lights in the door do not work. i have narrowed the cause down to i believe diodes in the dash somewhere over the glove box. can these be reached with out pilling the entire dash?
