I decided to install one of those ignition lights on my 89 s13 (two wires). I was told to tap into a black wire plug on right side of steering column under a purple wire and also the solid red wire with blue stripe. Did so and the lil ignition key light came on just fine ( i only used connectors and didnt have them wrapped...)
i just stuffed everything back in and i heard like a pop noise and the bulb went out . . . i think the power wire may have grounded out somewhere. i thought it sounded like the bulb blew, but i checked it on battery and it worked fine.
Dash lights didnt work that night. I soldered the wires back together leaving the ignition key light off this time and put everything back the way i had it . . .
now - dash light doesnt work - my autozone boost gauge doesnt light up ( but everything else functions . .boost gauge, speedo, tach, other warning lights )
do i need to replace the time control unit ? (lil white box by kick panel)or do i need to look at something else?
HELP - cant see s*** at nighttime
