dash lights dont work
90coupe
Car: 90 240sx coupe
just bought a 90 coupe and the dash lights dont come on when i turn on the headlights is there a fuse for this and if so where is it
1991S13
Car: '91 240sx Coupe, '00 QX4 4x4, '02 Sentra Spec V
Use the search button in the upper right corner to find answers to questions like these. Also, the FAQ section is your best friend now! People on here don't like to spoon feed the easy-to-find answers to people who don't do their research (even though NICO is full of a bunch of very kind guys/girls, lol).
Do you have digital or analog guages? If digital, it is a very common, very covered problem. Here is the site I found that helped me fix mine:http://multi-index.myonlinesit...o.htm
Nismo_Freak
Car: 89 Nissan 240SX
90coupe wrote:just bought a 90 coupe and the dash lights dont come on when i turn on the headlights is there a fuse for this and if so where is it
Might be a bad dimmer switch.
johnnyknoxvillej
Car: 89 sr
check the taillight fuse the cluster lights are wired w/ them
spider_slayer
Car: S14 240SX
S13 240SX
this happens to me as well. each time i turn on my headlights the taillights/dash fuse blows. i havn't been able to fix it yet but i heard alot of guys have been able to fix this by simply changing the taillight bulbs.
Nismo_Freak
spider_slayer wrote:this happens to me as well. each time i turn on my headlights the taillights/dash fuse blows. i havn't been able to fix it yet but i heard alot of guys have been able to fix this by simply changing the taillight bulbs.
Possible but you are simply pulling too much current, I'd check for shorts.
TAMHA101
Car: 1992 NISSAN 240SX HATCH BACK
LET THERE BE LIGHT!!! I finally got my dash lights to work. What you need to do is look at where the fuseses are, there is a little white box right beside it, try and replace it with a new one. Thats what I did.
180fan
Car: 89 fastback
yep first thing to check for are the sockets for carbon deposits. clean out the deposits and it'll stop shorting out right at that socket.
smokin240
You all are lucky. NONE of my interior lights work, not even my cluster gauge ones, or my radio. I have little light in there rigged for a switch I made so I can so how fast I'm going at night :-)
vancouverbc
Car: 1991 240sx
article on white box:zerothread/158162
jdm538
Car: bang bus
this is such a common problem, but glad people know how to fix it. i got to go get a white box now.
evan86
Car: 1990 240sx, 1996 300zx twin turbo
So is the TCU problem dash light specific? I have both dash and tail lights out and switching in a new fuse did nothing. It sounds like you guys with the TCU problem only have non-working dash lights.
slimcat7m3
Car: s13
I have dash and taillights out, replaced the tcu, but problem persists. Its not the light switch, and not the bulbs. I pulled all of the lights off and the fuse still blows, on about fuse 20, all of my lights have continuity to them when they are not supposed to so the problem is before that. Let me know if you find anything I will do the same.
ricebike
2002 Quest
2005 Altima
slim, your particular problem= short
u gotta trace dose wires, yo & find it
JayNoel
Car: 90 RBZ32 rescue project
slimcat7m3 wrote:I have dash and taillights out, replaced the tcu, but problem persists. Its not the light switch, and not the bulbs. I pulled all of the lights off and the fuse still blows, on about fuse 20, all of my lights have continuity to them when they are not supposed to so the problem is before that. Let me know if you find anything I will do the same.
i got the same problem on my s14 im getting about 58 amps to the fuse box where the running and dash lights fuse is located ive traced wires and found nothing
kida runing out of ideas
Azrial
Car: 93 240sx vert, 1990 pignose hatchback roller
Time to rewire it yourself.
