dasCOUPE »
https://forums.nicoclub.com/dascoupe-u259125.html
Tue Dec 08, 2015 12:13 am
Ok i got some more information that could be useful... try using standard bulbs see if the problem persists sometimes LEDs can cause this from what im told.
Also check the diodes pins etc make sure everythings working like it shows in the fsm the illumination circuit travels across some diodes on the back of the cluster although im not totally sure that would create this issue if say one was bad.
From what i been told the tcu doesn't cause this I've checked mine with a multimeter readings seemed good.
Check the connections on the cluster and for any signs of damages as well, the thing is pushing beyond its life expectancy and may need careful soldering and electrical maintenance ($100+ if you can find a good electricical technician)
Hope that helps ill work on mine some and edit in results, if anyone has some good input please don't hesitate to add driving at night not seeing the temp is most risky...
