Thank you. I'll give it a try. Any idea why the ABS light would be on?BLkSickTT wrote:my brake light comes on sometime but all my lights are good. There is a way you can reset your airbag light unless your airbag sensor is bad. Look by driver side door panel there is little black switch press it like 5 times by slowly and putting ignition on only and then shut it off all the way and restart should go away. Hope it helps
300zxaboveall wrote:Does anyone know why the ABS and Airbag lights might be on? Also, when I hit the brakes, the brake light on comes on by the ABS light. Is this normal?
