dash light wont work on j30
tony96
Car: 1993 infiniti j30t
i have a 93 j30t and my dash lights and the rest of my interior lights except my dome light and my map lights. wont come on when i turn on my head lights. but when i turn my alarm on my dash lights and the rest of the lights flash on and off. so i know they work. so i think it could be the dimmer switch. does anyone know where i can get the dimmer switch.
driverdriver
Car: NICO's longtime resident Canuck!!!
Try the forum sponsor. I believe its a plug and play part.
VimyJJ
Car: 95 J30t
You can try cleaning the dimmer switch and I'll bet you'll be good to go.
tony96
i tried to clean it already, no go
DurtyJ30
Car: 1995 Infinity J30T
im having the smae problem, how would i clean the dimmer switch its kinda hard to get anything between the crack
Remove and replace.
It's like $22 IIRC.
tony96
found the problem it was the fuse behind the cluster..
94j
Car: Infiniti J30
Could you give me more info on the "fuse behind the cluster"? I'd love to find a simple fix to getting the dash light working again. Thanks!
J30tman
I had to take the dimmer switch out and re-solder the connections on the inside. Easy fix. I was completely done in 20 minutes. Most anyone can do this.
vocoder
tony96 wrote:found the problem it was the fuse behind the cluster..
i have the same problem
can you tell me where did you find that fuse????
rich9442
Does your glove compartment light work? If not change the fuse and the dash lights will work. Had same problem
deeohgee81
My glove box lights dont work either. Where is this fuse you say I can change and solve the problem?
DavDaddy
Car: 1993 j30
I too need to know the location of this fuse?
Rogue One
Car: 2011 Nissan Rogue SL
2012 Nissan Rogue SL
2022 Honda Pilot SE
2025 Honda CR-V Sport L
DavDaddy wrote:I too need to know the location of this fuse?
Welcome to NICO! Sorry to hear that your car is having trouble. I'm not all too well versed in your vehicle, but can offer an option for you. Here at NICO, we have Factory Service Manuals available free to members. Take a look at the link in my signature and find the FSM for your car and you'll have all the info you'll ever need to make the repair and try to diagnose it for yourself while help is on the way.
