dash light went out
Discussion forum for body kits, repair, modifications, interior styling, Audio / Video and internal/external lighting.
mberu2
Car: 04 g35 sedan rwd
Hi guys I need help I change the cluster light after I put everything back together now the gauges light dont work everythink else work perfect I check all the fuses all of them is good I don't know what else to check
audtatious
You changed the cluster light and when put together the light for the gauges don't work? Sounds like you need to take it back apart and validate the connections are solid and the other bulb is actually not blown.
mberu2
I did it already and nothing i don't know what else to do people
Tell me i have to buy a new instrument cluster
audtatious
You have to buy a new instrument cluster
Actually, break out a multimeter and see if the cluster bulbs are getting power. Also, make sure the brightness for the gauge cluster is actually not turned all the way down.
Return to “G35 and G37 Interior, Exterior and Audio”
