dentedfender240 »
https://forums.nicoclub.com/dentedfender240-u28822.html
Tue May 17, 2005 1:31 pm
also everything else works (as far as i know because i havent started it but I bought a used one.) like speedo, rpms, fuel, temp, all the warning lamps still work, headlights, brakes, tails, sidemarkers, turnsignals did function at first but dont now but its due to a completely unrelated issue. the turn signals did work on the dash as well as the high beams i was thinking about changing the bulbs first, figure go cheapest to most expensive until the problem is solved. anymore help would be greatly apperciated man
