DASH KIT (RADIO)
BLK_EIGHT
Hello... just purchased my 2010 Rogue SL 2 days ago... looking at my first mod to replace factory standard (non bose) system with a doubl din (no nav)... my question is about the dash kit... im not thrilled about the black/greyish color... has anybody painted the dash kit? im thinking something silver to match some of the silver in the car? if so, what kind of paint, etc..????
thanks again.
philipa_240sx
You may wish to try searching the audio forum:
zeroforum?id=99
I have never painted interior trim pieces, but here are a few suggestions:
1) Surface prep is the most important. The surface must be sanded smooth, washed, and degreased. There are typically all kinds of oils, mold release agents, etc on plastics and you have to remove them for the paint to stick.
2) Use a primer made specifically for plastic parts. I would try auto parts stores or places that specialize in automotive paint. Duplicolor makes and adhesion promoter/primer that should work well:
http://www.duplicolor.com/products/adhesion.html
3) For the color coats and clear coats, you can use a wide variety of automotive spray paints. Duplicolor has a few options in thier product line as do many others. I am no expert in painting so try Duplicolor's website for painting tips:
http://www.duplicolor.com/index.html
A few more tips:1) If you decide to paint the HVAC console under the radio, be forewarned there is an airbag indicator light. If you disconnect it and try to turn the ignition key to ON, it will give you and airbag check/warning light. There is a way to clear it:
zerothread/398407
If that does not work, you may need to take it to the dealer.
2) The plastic scratches quite easily. Be careful removing components and use a cloth where needed to protect surrounding trim pieces.
3) IMHO a nice effect could be achieved by painting the following:
- HVAC vents above the radio- HVAC console below radio- The silver shifter bezel- Door handle inserts
If you need help removing the interior trim, please look at the manuals here:
http://www.nicoclub.com/FSM/Rogue/
takeshi
Car: 2008 Nissan Rogue SL AWD
Guess it's a subjective matter but the color of this dash kit (photo is Leo2005's) seems to match. I personally can't imagine painting or dying it silver but to each his own...
casperfun
Car: 2009 Nissan Rogue SL AWD - Indigo Blue
To each his own:
Modified by casperfun at 9:43 AM 2/25/2010
kerrton
Car: 2008 Nissan Rogue SL FWD Gotham Gray
Yeah that dash kit looks really sweet casperfun.
You can choose from probably 10 or more colors and designs from various sellers on ebay, but they are custom fit to the stock Rogue radio as far as I know.
If you remove the stock radio and add an aftermarket unit with faceplate I doubt there is a dash kit that would fit, but you can always do a search and see what's out there. If you could find a silver/metallic overlay kit to stick over top that would be much better than trying to paint the face plate, in my opinion. Like Philip said it's definately possible to paint a plastic pieces but I'd be unsure if the end result would meet my expectations, whereas the stick on overlays can be viewed prior to purchasing....let us know what you end up doing...
BLK_EIGHT
Thanks for all the info. I'm not looking for an entire dash kit just a different color stereo kit/plate. I understand the ones being sold match perfect to the cars interiro but it just looks so plain.... im looking for either a silver double din unit (if anybody knows of one) or a silver kit. Im trying to keep the black with silver accents going and that part of the car is just too dull.
paulvanharte
Carbon Silver
Is the Rogue pic yours?? I am thinking about doing the same. Where did you get the kit???
Paul
casperfun
No its the forum member dolbydj. That's his modified Rogue.
Return to “Rogue Forum”
