jmn4667 »
https://forums.nicoclub.com/jmn4667-u175135.html
Fri Jan 28, 2011 6:49 am
I have a 2009 G37S which has the high-mounted "fog" lights; inside of the headlight casings. When I turn them on, the fog light indicator light on the dash (far left side) does NOT illuminate (it never has). Is this normal? I drove a 2010 G37 the other day, which has the updated front with "fog" lights mounted in the grill, and the indicator light worked fine.
If mine should illuminate, could this be a fuse issue? I'd hate to have to pull the dash to fix it.
Thanks!
