Dash illumination issues
tmnismo91
When I bought the car four years ago, I didn't have any dash illumination when the parking or headlights were on. First I toggled the dimmer switch which didn't work. Then I replaced the switch with a new one, no luck. Finally I shorted two wires which provided full intensity when the lights are on. The problem is that my eyes tire of the intense light constantly and I would like to be able to dim the light at times. What needs to be replaced under the dash? Someone mentioned a white box called the timing control unit? Can't see a white box. Any ideas?
-Sean
tmnismo91
Disregard this thread. I found the box.
-Sean
L0sT
could someone please post a pic of this timing control unit? im not 100% sure what it looks like...do i have to remove that plastic square cover to see it?
NISTECH
its a white box about 5" long by 4" wide by 1.5" thick. yes you will need to remove the trim to see it.
L0sT
how many wires or harnesses are going into the tcm? is it hanging loose are is it bracketed to something?
NISTECH
it should be made of plastic ,attached to some part of the dash with a braket, 1 connector with approx 10 to 20 wires in that connector(rough guess). it should be the only white plastic box about that size under your dash.
L0sT
i dont have any friends with a 240, so is there a place online that has this in stock, i really dont wanna go to the dealership because they'll prolly not know what it is, and if they do have it, theyll prolly charge me a ****load
thanks
NISTECH
on the 240s I believe its in the kick panel by the fuse box. The dealer will know what it is if you call them. but when you do call dont use the acronym cause they may mistake it for the transmission control unit.
L0sT
is it timing control unit or timing control module??
NISTECH
it gets called both depends on who is reffering to it. you just dont want to use the acronym since the parts guy might call it something else.
