Find the two big bolts under the dash that are holding the steering column in place. Loosen them, so the entire column drops an inch or so. That will give you plenty of clearance. Ignore the joker who told you to remove the steering wheel.240nismo wrote:The dash is being takin apart, and i can't get the bezel behind the steering wheel and in front of the gauge cluster out. The tilt Knob keeps getting in the way and i can't see how to take that off either... help!:help
