Dash cluster help..
Red-S13
Car: 1989 240SX (in the works)
Okay... '89 S13 is the car..
Now the problem.
Alright, so my cluster doesn't light up.. the only part that does is the clock.. and that's only when the running/headlights are OFF. My speedometer projection-onto-the-windshield (someone tell me what that's actually called, please?) doesn't come on/show up at night.
And my normal digital speedometer sometimes stays on for a few secs after I turn the car on before it shuts off.. so I have no idea how fast I'm going at any point in time! I definately don't need any tickets right now. I'm too broke to pay on after buying my car..
Is there like.. a short or something? A loose plug or wire? How much trouble would it be to install a new cluster or take out the one I have and look at the plugs?
Although if someone told me how to tell when I'm going approximately 40mph in 4th AND 5th gear on a stock KA eng. and stock transmission from the RPM gauge I may be able to live without a ticket until my cluster is fixed..
sommmatt
Car: 1989 Nissan 240SX
No idea what your problems are, because I fail at wiring, but the windshield thing is called a Heads Up Display.
Red-S13
Bump.
240_SeX
Car: 1992 240SX SE
I have the same problem, i dont have HUD tho. if you havent fixedd it by now lmk and ill explain what i found
Red Devil
Car: 1990 240SX w/t SR20
2008 Nissan Versa SL
Bad electrical components, old soldering, or loose wires are most likely.
