esd51918 »
https://forums.nicoclub.com/esd51918-u145651.html
Mon Jul 25, 2011 7:17 pm
There is no need to cut and solder anything so long as you get the harness that goes with the analog cluster like Compact says in his post. The harness for the HUD cluster and the analog cluster are different only where they plug into the back of the cluster. The other end of each harness is the same where they plug into the main harness under the dash. That's why you want the harness that goes with the analog cluster. I replaced the HUD cluster in my 89 coupe with an analog cluster. I made sure that I got the harness that went with the analog cluster. It plugged right in, no problem.
