dash and gauges
A home for 1983–1989 300ZX owners!
bigred240sx
Car: 91 240sx fb w/ super hicas(wrecked)
1976 280z
2009 frontier
I have had my car since march and am just now getting to dash repair but anyways what do i do to take out my gauges to replace bulbs and to remove the dash
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
it's not htat hard, the dhash you need to pull the metal cover between it and the windshield which had 4 or 5 phillips head screws, then you can see the 4 ro 5 10 mm head bolts holding the top of the dash in, there is a couple more at the bottom of each end and a couple more on each side of the trans tunnel, you will have to lower the steering colums which is just a couple more bolts and pull the steering wheel, and there are a handfull of electrical connections at each eng and around the column, a few more in the center and a handful of plastic ducts to disconnect, it sounds more difficult than it is, the S30 is the easiest dash I have ever removed
and if you are just replacing gauges and bulbs you don't have to pull the dash, there is just one or 2 bolts holding each gauge in, really small, like 7 or 8mm, kinda hard to get to without pulling the dash but not too bad, and if it's just the bulbs they pop in from the back and you don't even have to pull the gauges
if you
bigred240sx
1976 280z
2009 frontier
ok but i figured it may be easier to put the dash cover on if i took it out and while i was at it was gonna swap that stuff out
evildky
06 Nissan 350Z GT
I think applying the cap is easier whith the dash installed int he car, that way it's held in place and straight, so you can push and press the cap on and know that it's not gonna pop off when you start to reinstall it, but I havn't personaly done a dash cap so your way may be better, I just thought you were gonna pull the dash just to change gauges and it's pretty easy to get to them withthe dash in the car, let us know how it wroks out
bigred240sx
1976 280z
2009 frontier
ok i havent done it yet...but i have yet to see some screws for the gauges in center console
Return to “300ZX (Z31) Forum”
