Darn Power antenna - suggestions? (pic)
Vmo
Car: '99 Q45
Well it looks as if the sunroof drain tube got clogged and it backed up into the power antenna casing - causing the bottom half of the circuit board to short and corrode.
The film is peeling off the back of the board so I can't remove and resolder the $5 or so worth of parts. Anyone else had this problem? Any other cars with compatible pwr antennas that don't cost $200 from Infiniti? lol
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Did you try IoS?
http://www.infinitipartssua.com
Now you know why we are so big on preventative maintenance as failed systems repalcement is expensive.
Might try a junkyard board.
Vmo
Car: '99 Q45
I'm all about preventive maint - I made sure to lube the mast regularly, but I guess checking the sunroof tubes slipped through the cracks. There are cheaper alternatives on ebay, but I think I'll snoop through the JY's first and see what they've got.
Thanks
qship96
Car: 1996 Infiniti Q45
Always retract the antenna when cruising at 130MPH and above, as the wind slightly bends the mast causing retraction problems....dont ask how I know
Infinitiguy19
Car: 1993 Infiniti Q45 188580 Miles
1994 Infiniti Q45a 240000 Miles
We should make it more aerodynamic.
But I have the whole antenna set up from a 1991 Q45 if it fits.
Q451990
I don't recall the 1st gen having a circuit board...
Check out http://www.car-part.com for used. I have never head of this before, so you have a decent chance of getting a good one used.
Heath
