Thought petroleum lubricants on the O-rings were a real no-no according to TexasOil.3rd Q wrote:Jesda,I've replaced 28 injectors between my 3 Qs .... Apply a thin coating of vaseline to the new O rings to help them seat easier
Can't see why a thin coat would harm anything, sure wouldn't do anything to the O-rings. Enlighten me.maxnix wrote:Thought petroleum lubricants on the O-rings were a real no-no according to TexasOil.
The second one.Jesda wrote:Which one should I purchase?
Head tech at the dealer suggested it. No ill effects in 10 years of driving Qs.maxnix wrote:Thought petroleum lubricants on the O-rings were a real no-no according to TexasOil.
Hope to tell my illustrated chain guide story to you all this weekend.elwesso wrote:Off topic, but paul, are you going to post those pictures.....
The O-lube is petroleum-based and not intended for use on o-rings made of silicone, butyl or ethylene propylene 'cause it will deteriorate seals made from those materials. I would think the gasoline would wash away any vasoline on the inside of the seals. Their other product is probably water-based. Anyone know what the factory injector seals are made of?3rd Q wrote:
Great vendor link. Just happened to be playing with a fuel rail this week. For reference, the screws are M5x.80 thread, and are 18mm long. Hopefully the heads are about the same diameter as OEM. You can get a bag of 100 18-8 SS screws for $11.55 from that link. Or save a few bucks and get 20mm screws--not like they're going to bottom out in a thru-hole.aaronl wrote:http://www.mcmaster.com/nav/enter.asp?pagenum=2934
