Darius' Build is finally complete
Darius
Car: RB25DET S14 - 665 WHP (SOLD)
I wanted to update everyone to show that I've been hard at work after having to pull the entire motor and take it apart to resurface the block. I figured that would be a good time to build the bottom end, so I bought RB26DETT rods and CP forged (86mm) pistons, magnafluxed and micropolished the crank, added a JUN oil drive collar, balanced the rods/pistons, installed a Tomei oil orifice (1.5mm) and blocked the front oil feed, installed new HKS cams and Tomei valve springs, new Cometic head gasket (lets hope this one seals or I'll burn their office down ), OEM gasket kit, N1 oil pump, OEM water pump, and a bunch of other miscellaneous shyte I don't feel like typing out. You get the picture.
I am going to have to post the pics as attachments because the gallery is giving me some ghey thumbnail error when I try to upload them.
Darius
New King Bearings (std size)
Darius
JUN oil collar
Darius
BLING!
Darius
More bling!...ok I've used my quota of "bling" for the month.
Shocker
Car: 89 240sxHB rb26/30
awesome, now put it in and fire her up.
Carl H
looks good man, glad you took the time to do some oil system mods while you were at it, going to fit external drains as well?are those the oem main bolts...im not sure i would use those again, and remember mad crazy amounts of assembly lube EVERAYWAHR!
Darius
Did it! I drove it last night and let me tell you, those HKS cams make the exhaust about twice as loud. I'm not complaining, but it really thumps. My exhaust hangs so low and the road construction near my house makes it a challenge to get out without scraping. Plus after having the thing in the works for two years I'm a ***** about actually driving it. The only issue I see at the moment is the exhaust tip knocking against my bumper because of my misalignment when I created the test pipe. Other than that, the motor runs great.
RBadam
Car: 240sx
congradulations on getting it running, i know yhe feeling of just dumping money into a non running car, (rip bmw ) sound lit your gonna have a a great time once all the quirks are worked out
Shocker
well good to see you have her on the road man!! awesome!, but you running standard turbo? whats the setup as far as power adders is concerned?
Darius
Carl H - Those are ARP main bolts and rod bolts. No plans for external oil return yet. I haven't really looked into it since I installed the oil restrictor and blockage. I figure that should solve the problem at its source.
Shocker - I am planning on running the stock turbo and intercooler etc. until I get used to driving it, the motor is broken in, and I save up some cash for a new setup. In a year, I am planning on doing fuel, turbo, intercooler, external WG, blow thru Q45 MAF, PFC, FMIC, and all that fun stuff. Looking for about 500 hp maybe a pinch more.
l0nestar
Car: 1993 Nissan 250SX
2004 Toyota Altezza
1963 Chevy Impala SS
Congrats man! Glad to hear you got everything in and running! I can't wait to get mine running. Anyways, glad to hear it finally runs!
Chaos the Xile
Car: 1974 Datsun 260Z
Hey just a heads up on the Q45 MAF. With Blow-Thru it makes the car run really, really rich. I'd set it up normal, unless you got a balklin' *** tuner. I was running blow thru not too long ago on my RB25 and its no different than have the MAF on the turbo. I'd got a 3Bar MAP Sensor and call it a day. Looks good btw can't wait to see more!
BTW - What size cams did you buy?
krayton
looks awesome darius
just the cams and valve springs to the head?
mind i ask how much those springs were?
cdorhout
Car: RB30DET with VCT -- SOLD!!!!
Next project TBD
Chaos the Xile wrote:Hey just a heads up on the Q45 MAF. With Blow-Thru it makes the car run really, really rich. I'd set it up normal, unless you got a balklin' *** tuner.
I think Darius is gonna set the MAF up the same way I did. Q45 Blow-through. Since he's also planning a PFC it's a piece 'o cake to tune the car on the street, especially with FC Datalogit software. I'm currently running a sweet air/fuel ratio all the way to redline and getting 25mpg at cruising speed with only 5 sessions with the Datalogit software.Throttle response is much better with the MAF so close to the TB also. You know Darius likes his bling, so he wants that sweet Atmo BOV sound too. LOL
RB20DETodd
Car: 92 Nissan S13 coupe SE RB20DET
DAMN DUDE THAT LOOKS SO AWESOME.
Darius
hahahaha yeah I like my bling so much that I would recirc my aftermarket BOV and retain my stock sidemount IC if I could
I have pics of the motor installed but I haven't gotten a chance to get them uploaded from the camera. I think you guys will like those just as much.
Chaos and Krayton - the cams are 256 duration 8.9mm lift I believe. I got them from Nengun.com because I was buying a ton of other stuff from them at the time and they had the best price. I think the cams were $380 each and the springs were like $120 or something.
I finally took it on the road this afternoon and drove in some traffic, (got the air bubble out of my master cylinder Chad) I don't know if my tach is off or what, but I can hear the turbo start to spool up at 2000 rpms. Is that normal?
Thanks for the compliments. There's still more to come.
krayton
^sweetness
what was the turnaround from negun?
and did u run the car without the cams before? looking what u feel going from stock to those
RB20DETodd
krayton wrote:^sweetness
sorry to hijack, i am curious about nengun, whats the deal the prices are good, whats the catch lol.
Shocker
dude I get full boost at 2300 is perfectly normal lol. Stock turbo might as well be a supercharger. glad your enjoying her!
Darius
I've ordered a couple of times from them and their turnaround is a week and shipping takes about a week and a half to two weeks. They have good prices because they don't jack up the price like US companies do to cover the additional shipping charges plus make a profit. They can ship directly to you and you save money vs. buying from a US based shop.
I put the cams in after I tore the thing apart for the third time. The only real difference that I could notice is the sound of the exhaust note. It has a more distinct pulse and is definitely louder.
About the boost thing, so when I'm going down the highway at 70 and creating boost, is that normal too? Seems like you wouldn't want to be building boost unless you put the pedal down.
Shocker
Darius, If you have a Pod Filter the compressor is noticeably louder, air is just rushing inside, creating that shhhhhhh sound when on the peddle, if you have a boost gauge hooked up watch it, it will make that noise even in vacume under slight accelleration in top gear while cruising. It takes about 1/3 1/2 peddle to create boost. But gasmilage isnt bad if your at cruiseing. I drove 380 miles on a tank before with my 25, was all freeway but pretty damn good. Granted I hit WOT only like 3 times the whole trip.
98birdls1
Car: 1998 Trans Am
Congrats Matt. Good to see it finally together. How did you shop put the collar on? Only directions I can find are in Japanese and dont help me any?
Good to see you went with the King Bearings. Drive that thing everywhere to break it in so you can take it to a track somewhere to show what those cams really help you with.
Luke
Darius
I brought the JUN instructions into the machine shop and apparently the symbols they use to describe what to do are universal. There are numerical dimensions on there as well that help them understand. My guy said it was no problem for him and it turned out fine.
gawdzilla
Car: none
congrats man, bout time that thing got running! hurry up and break it in so you can wail on it:)
Kansei240sx
Car: S13 - RB25 Circuit car
71 240z - street/track day car
AE86 - Daily Drizzle/track day car
Z31t - Paper weight/street car
HELL YEAH! Man im happy for you, you've had so many problems, yet you stuck with it hardcore like a true nissan owner. Props times two.
Carl H
yaya powahz.i would get a z32 maf instead of a q45, it has a much finer resolution compared to the q45...better for tuning.
Chaos the Xile
Yeah I'm not using blow thru but i've had my PFC tuned with datalogit and it runs fine atmos-bov and all like to see pics of you motor...
Darius
Ok guys. Here are the pics of the engine bay as I promised. The wiring on the passenger side of the motor still needs a little organizing, but I can do that when the car is stored over the winter. For $9000 in parts, the thing looks stock.
Darius
A second shot. My personal favorite
