DanDrath wrote: I figured the easiest way to ask all my questions is to just make my own thread.
My newest question/issue: I think the reason for my braking up issue is the timing. I unplugged my bad o2 sensor and the cars running better but still braking up at about 4k and like chugging trying to go. Its weird. Anyway my automotive teacher took a ride and said he thinks its timing which now makes 3 mechanics and my own opinion that its a timing issue. Could adjusting the cass possibly fix this? If so does anybody know how to adjust it.All help is greatly appreciated
Thanks and please read this whole thing lol.
What is listed above is the way to set ignition timing, and it is important to remember the CAS should be close to the middle of the settings. If you can't get it to 15 deg or the CAS is set way to one side or the other, then you likely have a valve timing issue and need to check the timing belt.
Next, do yourself a favor and clean every electrical connector. The Z suffers from corrosion on the connectors. Clean the MAF, PTU, CAS, coil packs and injector connectors (if you really feel adventurous, clean the idle connectors as well). Dirty connectors can look like all kinds of problems, timing especially.
